I thought about it last night. With this Covid 19 forcing everyone to work from home, it slows the web down severely, especially mine. What if when you create a project with easel, you could store it on your home PC so you could carve it with a slow internet connection? This may already be a feature that I haven’t discovered yet.
Using Easel to control and carve do not require internet access nor consume bandwidth.
Opening Easel / load and save projects require internet access, but past that point its not required.
You can export your files (download as Zip-file IIRC) and run using a different sender program like UGS to run the carve.
