Hello all,
if these are stupid questions - please forgive.
is there a way to ‘save’ a design found in the ‘design library’? as you likely know there are thousands (or more) designs in there. It takes a LOT of time sifting through trying to find something that I want/need to use. Is there a “my designs” or “favorites” option somewhere to save frequently used designs?
this question is an off shoot from the first. Last year I spent hours designing a product. Through many iterations, I finally got it right and sent out a few of the prototypes. I just received an order for that product, and… IT’S GONE!!! VANASHED!!! it is NOT in my projects listing. So now I get to spend hours redesigning it. As such, I have learned from this misfortune. So, my question is this: is there a way to load all of my projects onto an external hard drive? If so, how?
Hopefully the Easel team can chime into why a project might have disappeared (I’ve never had that, myself).
You can’t exactly backup a project. Meaning, you can’t back it up and restore it exactly.
There is an option to download the project as a ZIP. If you do this, it will give you a file that contains an SVG with the basic design for each workpiece, and a text file with some (but not all) of the properties for running each workpiece.
You can re-import the SVG to at least get the design back, but the text file will not include enough information to recreate the project perfectly. Also, any non-vector features (i.e., notes and—I think—groups) will not be restored. It’s useful for backing up something that you have no other way to restore.
Honestly, for anything too complex, I generally prefer to design it in a different tool (Illustrator or Inkscape, for example), then import the SVG into Easel. Those programs have much better tools for complicated designs, and also make it much easier to iterate.
Thank you Phil,
I too hope that Inventables designers see this. It seems that with every problem that I encounter (and there are A LOT), the advice is to use a different software program. I’m a woodworker, NOT a computer guy, so this journey has been brutal, as soooo often when something doesn’t work I just want to grab a 100 year old tool and get the d@mned thing DONE!! but that’s not how I will learn, so I force myself to go through the design HELL day after day.
I’m getting to the point where I may have to shut down the shop, get a job, take some computer night classes to learn these other programs that different users keep telling me to use, and try again in a year or two.
so, IF any designers are reading this - HELP!!! If you would like input, I would be happy to do a phone call. If you want to make your software idiot-proof, employ an idiot. I volunteer, and will work with you for FREE if it means that the software can get to the point where everyone doesn’t tell me to go learn how to use a different software each time I try to build something.
all my best,
Joe
