Saving $ setting in machine inspector
How do I save a change I have made in machine inspector: I changed $102 from188.976 to 95.500 because I added a new linear rail, but can’t seem to save it
“$102=95.50” make sure you refresh
You need to hit refresh and also reset of your controller might be in order aswell.
There is no specific “Save” button / command.
You cahnge the parameter by entering “$102=99.5” and click Enter.
Enter “$$” once more to see if $102 reflect change. Reset controller and you should be good to go.
That worked Thank you both for the quick reply
Thank you Phil. looking forward to that
