Secondary cut Easel Pro Question
Check the toolpaths first!
Twice and will do a test carve. What is that stuff called at Home Depot?
Home Depot has the pink stuff. It’s foam insulation found in the building materials department. The blue stuff is the same thing from Lowe’s
And I can use the same bits? What material type should I select in Easel?
Thanks
Material type does not matter. You will want to increase your speed and cut shallow. The foam will melt and stick to the bit if you are moving to slow. With that said the foam may still stick. If that happens pause the operation clean bit without moving anything and then continue. There is a specific bit made for foam from inventables. The key is to keep bit cool
