I am trying to engrave a flag that is from a group of 4 would apprciate some help
You can try using the XPloder App…
Or, you can double-click on the object in Easel and start deleting points.
Or, you can just cover up the objects you do not want to carve (if separated enough from the one you want to) using objects (squares, circles, etc.) with a cut depth of zero.
{:0)
Brandon R. Parker
