Free PicFRC License with the purchase of our PicLaser image to gcode program. PicFRC will expand the shades and enhance your 8bit laser diode engravings by adding a variable feedrate to the gcode.
When laser engraving 1bit B&W images/logos, it will increase the feedrate in white areas and slow to burn the Black areas for cutting down on the engraving time. Get the most out of your J-Tech laser attachment on your X-Carve.
Promotion ends at midnight September 30th.
www.picengrave.com/PicFRC.htm
www.piclaser.com
Image editing, resizing and gcode generation done with PicLaser. Then a variable feedrate was added to the gcode afterwards with PicFRC.
This was engraved on Poplar with a 2W 445nm Laser Diode.
To the author of PicLaser, PicEngrave Pro 5 & PicSender @JohnChamplain, I’M
Please wish John a Happy Birthday by adding your
Like to this post.
September Promotion
Thanks.
Jeff
Ha, ha, ha ha. Thank you my friend. I think it’s the best BD card(?) I ever got in my 76 years, certainly the most unique. Much appreciated.
Another PicLaser + PicFRC with a 2W LD on Poplar example.
PicLaser generated gcode is not only for Grayscale photo engraving with a Laser Diode, it can be used for Black & White image/logo Laser engraving also. The included image editor has 11 different Dithering Algorithms to choose from to convert your color or grayscale images to 1bit B&W for ON/OFF Laser control.
Using PicFRC to add a Feed Rate Change to a Dithered image generated gcode will increase the feedrate in white areas and slow to burn the black areas to cut down on the engraving time.
Here is a B&W Line Art image Laser engraved on Brown Chip board.
Last day of our September PicLaser + PicFRC Promotion.
www.piclaser.com
