Setting is mm but cut settings convert to crazy numbers when savedsaved
Any ideas? When I switch to mm in the lower left hand corner and attempt to add a new cut setting from the toolbox I get crazy numbers when I try to save the new cut setting.
Hmm, when I do those same steps, the cut settings appear normal and save normal as well. I’m unable to replicate your issue.
Maybe you can post some photos of the issue?
