THIS IS SOMEWHAT OF A REPOST JUST MOVING IT TO THE LASER SECTION
For the most part switching over to the laser was the easy part but when switching back seems to be when it all falls apart. when switching back to inventables hex file there seemed to be many complications with loss of connection to the xcarve adding up to many days of frustration. What I bring to the plate is my own personal ups and downs finding what worked for me. I found that there were too many versions of inventables hex to use and only one worked on my machine and when asking for help I would get directed to a different hex file and out of confusion and frustration I would try setting up with the wrong one by accident. Now with all the confusion out of the way switching between the 2 hex files is simple and flawless. But what worked for me may not work for you I am just sharing what worked for me. There are a lot of settings that can be adjusted to fine tune everything after all is up and running.
here are the hex files I use along with xloader
INVENTABLES HEX grbl0_9i_X_Carve_500mm_ACME (1).hex (80.3 KB)
JETCH HEX grbl.hex (79.1 KB)
XLOADER XLoader.zip (678.3 KB)
