I have changed my slide/z carriage and this has got a 16turn inch lead screw.
How and what do I need to change to get this to run correctly ? I had the acme lead screw in the original setup
Check out this thread, there is alot of good info. I used it when i did mine.
Thank you
Assuming you’re using GRBL the variable for Z-axis steps/mm is $102. NEMA bipolar motors are typically 1.8 degrees per step, which gives 200 steps per revolution. So…
16 revolutions/inch * 200 steps/revolution * 0.0393701 inches/mm = 125.98432 steps/mm
In the USG or Easel command line, enter $102=125.98432. This is assuming that it is direct-drive. If there’s a gear ratio, then multiply appropriately.
Also, never fully trust the data sheets, always measure your machine’s actual travel and adjust the steps/mm if needed. Calibration is always an iterative process.
Thank you
Thank you
Im probably not the sharpest knife in the drawer when it comes to these things
Think there is something im not getting right here…after iv entered these settings (125.98) i try to move 1mm in universal gcode sender and it only moves 0.48 mm,this cant be right ??? what am i missing ??
Btw i use picsender to change my settings
Hei, prøv $102 = 262,45
Mulig jeg er på bærtur
Nice I ended up with a value of 187.600 still not finished fine tuning it.Will try a bit more tomorrow.A big thank you for all the help
