Shapeoko xl
Hi there, new to all of this. I’ve tinkering with Easel and really like it, can someone tell me if it will work with the Shapeoko xl please. Thank you
The control is for both Arduino / GRBL based so yes - it will work.
Just use the Xcarve1000x1000 as default but you may be required to tweak the steps/mm in GRBL which may be different.
As well as tweaking some other settings.
Just an example with descriptions (DONT USE =x values)
$0=10 Step pulse, microseconds
$1=25 Step idle delay, milliseconds
$2=0 Step port invert, mask
$3=0 Direction port invert, mask
$4=0 Step enable invert, boolean
$5=0 Limit pins invert, boolean
$6=0 Probe pin invert, boolean
$10=1 Status report, mask
$11=0.010 Junction deviation, mm
$12=0.002 Arc tolerance, mm
$13=0 Report inches, boolean
$20=0 Soft limits, boolean
$21=0 Hard limits, boolean
$22=1 Homing cycle, boolean
$23=0 Homing dir invert, mask
$24=25.000 Homing feed, mm/min
$25=500.000 Homing seek, mm/min
$26=250 Homing debounce, milliseconds
$27=1.000 Homing pull-off, mm
$30=1000. Max spindle speed, RPM
$31=0. Min spindle speed, RPM
$32=0 Laser mode, boolean
MOST IMPORTANT:
$100=250.000 X steps/mm
$101=250.000 Y steps/mm
$102=250.000 Z steps/mm
$110=500.000 X Max rate, mm/min
$111=500.000 Y Max rate, mm/min
$112=500.000 Z Max rate, mm/min
$120=10.000 X Acceleration, mm/sec^2
$121=10.000 Y Acceleration, mm/sec^2
$122=10.000 Z Acceleration, mm/sec^2
$130=200.000 X Max travel, mm
$131=200.000 Y Max travel, mm
$132=200.000 Z Max travel, mm
