Sienci Labs Vortex
Hello X-Carve users. I was searching the web and came across the Sience Labs Vortex Rotary Axis. I took a look at the wiring diagram that is on there website and came to the following conclusion. By determining the pin out of the 4 pin connector and locating the plugs of the x-carve pro, male and femaile, the Sienci Labs rotary axis could be customized to work with the x-carve pro. The problem I am having is locating the cable connectors. As far as the Sienci LAbs connector they use Phoenix type connectors. If any one could help with this matter it would be greatly appreciated.
