After you click Simulate and view your tool paths and estimated working time, is there a way to toggle back to Detailed Preview? Thanks in advance. If there’s no formal process, please share your work around.
I might not be understanding correctly but if you change anything it will go back. Lets say your work is 16" long if you go up and change it from 16" back to 16" it should change and you should be abble to change or move anything and it should reset.
Thanks Wayne. Without changing anything. Pretty much done let’s say. Curious how long it’s gonna take. Click Simulate. Tools paths displayed and estimated time showing. Now you wanna see the detailed preview again.
That is about the only way i know how to do it.
Yeah just change something. I usually will just change a bit then hit the undo button and that clears the screen and restores the piece
Thanks guys.
Drag the slider to right then back to the left it will remove the tool path lines.
