i’ve been pushing my x-carve pro limits to see what this thing can handle.
today i tested cutting 3/4 plywood in 2 passes with a 3/16 coated compression bit. cuts are super clean. bit is room temp after cutting. wood is 90 degrees, so mild heat transfer.
-19000 spindle at 80 inches per minute .38 inch depth passes.
Has anyone tried cutting 3/4 inch plywood in a single pass? if so; what combination of bit/speed/feed did you use?
happy testing
