How do you change stepover for slab flattening. I have a 1 1///8 bit and see no place where i can change stepover
When I surfaced my table, I just drew parallel lines connected at every other end, spaced about half the diameter of my bit. The cut was on path.
There’s this thread:
You can go into tools and create a tool to match what you need. Bit size , step over , depth of cut. Then you have it when you want you can just select that tool and your good to go.
Also what I did was measure the out side profile to what you want to cut then use the pocket cut in raster to create the program for your cut.
Your right. I was thinking of a different prlgram i use.
