Hi,
Hope you get my issue.
So when cutting out inside patterns, is there anyway to slow the machine when it arrives to corners. Im using stock settings but it goes so fast at the corners that it goes abit out and the shape doesn’t look right.
Hi,
You can change the feed rate in the manual mode. The other option would be to open the gcode in a text editor like notepad and change the feed rate for those specific locations… that’s more work than just slowing the whole file down.
Hey,
Thank you for that, l did change speed and it did make a difference, will be testing further.
