We use cookies to personalize content, interact with our analytics companies, advertising networks and cooperatives, and demographic companies, provide social media features, and to analyze our traffic. Our social media, advertising and analytics partners may combine it with other information that youâve provided to them or that theyâve collected from your use of their services. Learn more.
When you start this loader, you will see similar windows as seen below.
Choose Hex File
Change device to same on picture
Change Comm port, which is yours (Check Device Manager)
Change Baud Rate to 115200
Make sure no other programs trying to connect. If web browser open, close it.
Then hit upload button.
After you finish, you must Start Easel and run Machine setup.
I tried and it was opened by VLC Media player. I tried to stop it but had no luck. Now whenever I try to open it, VLC hijacks it. No email from customer success today.
I downloaded Arduino again and tried to get the Grbl fork and when I tried to add the .zip library, this is the error message that I get in Arduino.
âSpecified folder/zip file does not contain a valid libraryâ
OK, Iâm grasping at straws here. I read that I should take the Grbl folder and put it in the Arduino Libraries folder and see if that works. When I open up Easel it is now stuck on âConnecting to X Carve.â So I reinstalled Easel Local, thinking that that was a problem and it still gets stuck. I donât know what else to do if I canât even get to the test page with the X, Y, Z arrows.
Did you e-mail to help@inventables.com. This Forum have tons of posts if you go search for identical problems. Everyone start getting a little tired repeating same answers, thatâs why you feel along. No panic. Try to do one at a time. If you didnât send anything to Arduino yet, my suggestion do not play with Grbl firmware. You may have another problem like missing windows components, Java, bad configuration data on your Web Browser are the few of them.
I just spoke to Sam at Inventables and she was kind enough to send out a new G shield and Arduino, hoping that will solve the problem. Very excited to get things up and running this weekend!
The entire time, the GShield was not fully inserted into the Arduino. The box that held them would not allow me to press the pins all the way down for a complete connection. I unscrewed it and took them out of the metal inclosure box and connected them and all of the lights came on! Thank you for all of your help and patients everyone involved!!!
Well, actually that is very common problem but we didnât think simple things. For that reason, I put two small plastic inserts on top of Gshield opposite corners, when Fan case is closed, pushing Gshield down. Because it would be loose again with vibration.
thanks in advance regarding this discussion I have the same problem but with one Difference,my OS is Windows, and it`s running out of the metal inclosure box but still the same
