Are you using 1/4" for Roughing and 1/8" for Finish?
Are you moving the gantry when changing the bit? Check your settings by going to the Machine Inspector and type in $$. Check what $1 is set to. It should be set to 255.
Do you have the X-Controller? If so, have you set the internal dip switches correctly? Check out the post below.
Is it consistently the same offset? Does the machine return to the original Work Home position? Have you attempted to perform a single bit air carve to see if the machine returns to the original Work Home position?
{:0)
Brandon Parker
