Hello,
Can anyone please help with a design issue I’m facing as a newbie in Easel and CNC.
I’m starting off with an 8.5mm plywood sheet that is 36.1cm x 22.3cm
I need to cut 60 circles in the board at precise locations/spacings.
The holes are on a grid of 6x10 holes.
The holes are 8mm in diameter, and each hole has 26mm at either side and up and down.
I’m using an 1/8” compression bit with a Makita router in a FoxAlien Masuter Pro.
I’ve chosen to cut circles rather than drill holes in order to give a cleaner finish.
I’ve attached 2 images. One shows the completed board with 60 holes, and one shows the spacing between the holes.
I’ve figured out how to create circles to the correct width, depth etc, but I’m struggling on the spacing and positioning of the board.
Thanks
Dave
