‘For all AC spindles, you can use the PWM signal from the X-Controller to activate a relay to turn the spindle on and off. When going through the machine setup, select the Dewalt 611 and the max RPM will be set to 1. The PWM signal will now act like a simple enable on/off output.’
For my control box to power my led lights I just gutted a 12v 1000 mah power supply like what comes with almost anything nowadays. And I just soldered wires to where the metal prongs were and hooked into the high voltage side of the relay . U can run a couple fans with that.
