Spoil Board
Hi All. New to forum. Researching x-carve. Spoil board looks like it’s only making contact slightly on all for corners. And bars under that. Does this need to be secured to table, and if so, two different heights (one spoil, two bars)
On the 500mm unit it is resting on the extrusion underneath the machine. On the 1000mm machine there is a brace underneath.
You don’t need to bolt it to the table or secure it further but you can if you want to. We do not secure any of the ones running in our shop to the table.
