I’m trying to square up my z-axis. Using my try square, I can see I have about a hair of discrepancy between top and bottom of the spindle mount. A slight forward lean of about 0.3 mm. Not much, but a little bit of inaccuracy here, a little bit of inaccuracy there - it all adds up.
The logical adjustment point are the four bolts on either end of the gantry extrusion; loosen bolts + twist extrusion (as far as possible) + retighten did get rid of the worst of the z-axis forward lean, but I still have a little bit more I need to shake.
Do I need to shim the z-axis to get it dead-square, or are there other points of adjustment i’m overlooking?
