I tried wedging for “tranning” on z axis, loosening belts, squaring up the y axis, squaring up x axis, tilting x axis up a little and securing side bolts, nothing is working… any help?
Hello @JordanKoppen, and welcome to the forum.
If you are talking about the deeper cut on the left, that does not look like a tramming issue to me. I can’t really make out down the image closer to the spindle. The image below is what you would see if your Z-Axis is just slightly out of tram with the X/Y plane.
Is this a file that you are carving from Easel? If it is, would you mind sharing it?
What are you trying to do? Do you have any more images showing what you are talking about?
{:0)
Brandon Parker
