Maybe. How much memory do you have, and how much is in use when trying to carve?
Look in your Task Manager to find out. Press Ctrl-Shift-Esc to pull up the Task Manager, and on the Performance tab, You will see CPU and the second is Memory. It will tell you how much is being used, and how much you have in total. If you are using more than 80%, then it is very likely using swap which slows things way down. This would be an indication that you need more RAM.
