Hi does anybody know if I can Import stl files into easel and if so how to do it thanks tom
No, Easel can not import STL files. Gcode from STL need to be generated using other programs (Vcarve?), Easel can send the gcode to the machine though.
Hopefully someone can provide a sound workflow for you.
I use Rhino 3d and save my projects as an STL. I use meshcam to generate the gcode. I run the gcode through the UGS, not Easel. Easel can import G code though by clicking on File/Import Gcode.
