Is there a way to put stretchers as backs instead of the full backs for the bases ?
I would say yes/no/maybe
I am doing it where I assign the back as a weird style of lumber and just ignore that part of the cut list. I chose inset, so nothing to fix there. Then put the stretchers where they need to go. I am using a table saw and manual assembly though, so if you are CNC this probably won’t work for you.
That’s actually a good idea I’ll put it as another material but same thickness and change the sizes later on !!
Thank you !!
