Suckit purchase
After reading through forum I am contemplating buying the Suckit. There are several choices. I need simple can anyone recommend which one I should go for with the 1000mm
Thanks in advance
I have all three iterations of their dust shoes. Get this one.
Thank you! Will order today
Out of curiosity, is there a reason why someone would choose a Suckit dust boot over what Inventables sells? Is this better somehow?
They’re essentially the same since SuckIt helped design the Inventables dust shoe. Inventables has a “better” mount system for the Xcarriage but it also is only available as a whole system, hose and hose support included.
If you don’t need that, you’d save $100+ going straight with SuckIt.
… and if you’re shipping to the UK, it’s much cheaper to just get the Suckit and sort out your own support.
