My first real week into using my X-carve I have been trying to do various projects using Easel and have encountered some challenges. Most of them have to do with homing problems. (And, yes, I have homing switches which I WON’T call limit switches because they do NOT act, in any way I can see, to limit damage to the machine if it starts to go out of bounds. At best, these switches only serve to zero/home the machine. Some REAL limit switches that instantly killed the motion of the machine would be nice.)
Specifcally, I’ve been trying to do small and detailed carves on birch plywood which require both a rough cut and a detail cut. These have used 1/8" bit for the rough cut and 1/32" (or an engraving bit or vbit) for the detail cut. My rough cuts usually proceed and complete just fine. But I’ve been mostly unsuccessful at getting a detail cut or quality finished carve after the rough cut.
The reasons for this are:
Easel seems to lose the “last home position” between cuts. This seems to be a software problem and it is NOT necessarily because the bit/collet was moved when changing bits. That is, I have managed to keep the spindle motionless while changing bits and yet Easel still loses the home position before I start the detail cut. Which, of course, screws up my carve.
Under normal operating conditions, when the machine finishes the rough cut, it returns the Dewalt 611 and spindle to the zero position. But that’s NOT a good thing because the normal zero position on the Z-axis is with the bit touching the surface of the material. And that makes it impossible to remove the rough cut bit and replace it with the detail cut bit without raising the bit and thereby losing the zero/home position.
What I’d like to see Inventables do to improve Easel for my X-carve is the following.
First, Easel now requires the user to do two completely separate cuts to complete such carves. After the rough cut, Easel takes the user to the “Did your carve complete?” dialog and then simply ends the process. But it would be much preferred if Easel considered the cut unfinished until both rough and detail cuts were complete. Easel needs to pause the two-cut carve process after the rough cut instead of considering that first rough cut as a finished cut.
Second, at the end of the rough cut, the spindle needs to move to the zero position and then raise the bit sufficiently (3 or 4 inches at least) so as to facilitate changing the bits.
Third, if Easel displayed the precise positions of the bit on the X, Y, and Z axes at the finish of the rough cut, and then allowed the user to reposition the spindle on all three axes before beginning the detail cut, then no matter what happened with homing, it would be possible for the user to precisely zero the machine for the detail cut to the position which was its zero for the rough cut. (Note: I recognize that doing this might be a problem without some built-in means of measuring the positions or counting motor steps.)
I also suspect that if Easel simply paused, instead of quitting, between the rough and detail cuts, that it might not be having its current problem of the software losing the zero/home position between cuts.
It would also be nice to be able to access the X,Y, and Z positioning arrows without having to go back into the machine setup or “start” a carve. Maybe make this a drop down on the menu bar?
Disclaimer: I’m still a relative noob with the X-carve so everything I perceive about it could be wrong.
