Support for edge banding
Description of the requested feature:
  • Add an option for edge banding on exposed and semi-exposed edges with the ability to specify the thickness of the edge banding to calculate panel sizes correctly.
What need or problem does this address?
  • Having to trim down panels after cutting them or resizing them manually before fabricating.
What area(s) of your workflow would this feature affect?
  • Design & manufacturing
    • Edge banding could be configured in the design stage or when generating cut lists
  • Estimating
    • Calculate how much edge banding is needed and include edge banding on estimates
What impact or value would this feature bring to you and other cabinetmakers?
  • Saves time and increases accuracy & quality of the finished product.
If applicable, please outline a scenario or example of how you or other users would use this feature and how it would impact or interact with your workflow.
  • My client wants to use a two-side prefinished plywood for their cabinets. The plywood manufacturer offers 1.5mm edge banding in the same color. Instead of having to manually resize the specific panels or trimming them down as a secondary fabrication step, I can apply edge banding to all exposed edges in my design which will automatically resize affected panels appropriately. Now I can manufacture my cabinets directly from my cut list!
Please include any images, links, or other references that help outline the proposed feature.
Can we have the option to put edge banding of different thicknesses on shelves, please
Screenshot 2025-01-09 150930
-This is the way I found to edit edge banding or place it. First, drawer fronts and doors, (which is the place EB affects the design). Are made from other material. So box is a type and doors and drawer front other.
-Then go to manufacturing tab and you will see the door and drawer sheet is separate from the rest
-At this stage you still have the doors in the original size without the EB removed
-Click (Export this cut list to Easel).
-Now you can resize your doors, drawers, depending the edge banding you are using (Ex: 1mm), offset inwards 1mm.
And that’s it folks!
or you can export the file to any other vector editor y tweak this thing.
