Bit I ordered from Amazon got lost in transit and I want to get started on a project.
Would this bit work in a pinch to surface better/faster than the 1/8" I have.
https://www.lowes.com/pd/Bosch-3-4-in-Carbide-Tipped-Straight-Router-Bit/1081969
Any suggestions on surfacing speeds?
https://www.amazon.com/gp/product/B07ZP5RXRP/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
That’s what I ordered from Amazon and I’m still going to get it, just USPS lost it And want to get going again faster on projects.
I’ve used 1/2" and 3/4" flat blades for this before, actually that same Bosch bit, but 1/2" variety. Depending on your tram alignment, you may get lines. Also, if you don’t have the speed/feed set right, you may get a little burning. Lines just take a little post-sanding, burns can be a bit deeper and take more time to clear out.
I found the best output is Y axis raster (front to back), the speed of the spindle varies depending on wood hardness. It’s been a while (I use surfacing bits now, such as this one - Amazon.com), but I think for hardwoods I used somewhere between 2 and 3 on the dewalt 611.
