I’ve been designing in Adobe Illustrator, saving as .svg and importing to Easel for a while now and no issues. Now, when I import my files into Easel, it’s reducing the file scale by 25%. I made sure that Easel and Illustrator are both on the same unit of measure (inches). Any ideas why I would be getting such a specific reduction (25%)?
I also tried .dxf import and it seemed to do okay. I’m alright with using that as a work-around, but would like to solve the .svg mystery.
Thanks for the help!
UPDATE …Found Solution
I found an old post that covered this same issue from a couple of years back. If I Export As and uncheck the Responsive box on the SVG Options, it scales it properly. Thanks for the old post!
