I apologize if this has been asked before, but my search found slightly different issues from mine.
I purchased and SVG file from etsy. I have only used easel pro for the last two years and haven’t needed an expansion. However, this svg does not look good on path cut or pocket, regardless of bit. I typically use a 90 degree v bit. Seller said to use vcarve. So I downloaded it and finally got it to work. However, not sure if the trial version lets me export the file to easel. I did the steps for the post-processor but I don’t see it in the program.
Any suggestions? Maybe to make the svg an outline only for easel? Don’t feel like purchasing vcarve especially since I haven’t needed it until today for one file.
In easel pro, I have tried the 60 at .05 and it looks like the image i posted above. .02 works but not as detailed and not on path like i suspected, how yours looks like… Should I try a 30 degree? I suspected because the board is small, it wont be as clear.
Ok looks just like mine. Thank you for the help, can’t believe I over looked that. Small font loses detail but better off than where I was lol. Thank you!
