Table dimensions
Hi
Could someone give me the dimensions required for the table top to house the big boy 1000mmx1000mm
I’m looking to build the house before buying the machine itself so it has somewhere to go straight away rather than having to move it later.
Thanks.
Mike
https://www.inventables.com/technologies/x-carve
Check out the machine footprint under technical specs at the bottom of the page.
If you’re planning on getting the sideboard, keep that in mind (you can find those dimensions listed as well).
i went with a 5’x5’ table for my 1000mm x 1000mm x carve. it has enough space around it for the sideboard, and enough for a laptop to sit comfortably in front or slightly off to one side.
