I have a 3/4’ piece of wood. I want my image to be cut out, so I chose 3/4 as my wood height, so it’ll cut all the way through. How do I know what the height of the tab should be? It’s defaulted to 0.080, but that cuts deeper than my piece of wood. I’ve already ruined 3 things because of this. (My image moved and got messed up.)
Also, it’s not even cutting all the way through. Should I lower the bit a little at the start, or should I add a bit more height to the piece of wood itself. (from 3/4 to 5/8, maybe???)
Hi Russell…
Thank you for your quick response.
I used a tape measure. It’s a piece of pine fencing.
How do I know what the height of the tabs should be?
