Cut a project went great, came back later and easel will not add tabs, tried another project same thing.
Make sure you set your material depth before you set the cut depth. If you do not do that, the tabs option will not show up.
Also, on a cut I ran last night, the tabs did not show up on the cut/graph side of the project, but showed up on the preview (and the tabs were in the final cut).
Did you cut the project out and it didn’t have tabs?
Its now freezing on “Generating Path” never gets past that.
Tabs came back but still will not
generate path
I think Easel has a bug with the last update…a few people have posted that it hangs up on generating toolpaths. I just tried it and it is freezing too.
Yes
