Templates for x-carve available?
Are the templates for the flat plates on xcarve available for public?
Im thinking about modifying the plates where the nema motors are mounted, and the ones that holds the Y axis makerslides
If you look at the plates in the inventables store there are drawings/files available for everything
Oh, i have missed that one… Thanks
But the dream scenario would be a file compatible with Fusion 360 :smiley:
The PDF files have accurate vectors drawings to scale. I used them to make my own taller endplates.
Awesome, Thanks :slight_smile:
I don’t know if all have them as I haven’t checked, but most have .step files available as well as a PDF drawing.
I have not used ones from inventables, but fusion will open .step files.
There’s a Solidworks version of the SO2:
and STEP/IGES:
and a few other formats for various versions are listed at: Shapeoko CNC Router, Rigid, Accurate, Reliable, and Affordable
here is the link to the files and you choose which part you want the choose download then select file type such as step stl etc etc.
these are from the original X-Carve but the plates you talk about are the same.
