I need to add Text to a 3D project . I don’t see a text menu.
Easel can Carve 3d using imported STL files only. You cannot Design or modify 3d models within Easel.
You either get to design using 2D/2.5D portion of easel OR Carve 3d from an existing STL file… You cannot add text to a 3d model within Easel.
You may try Blender, or another 3d modeling software to create the desired design as a 3D STL file then import that into Easel for generating toolpaths… But at that Point you’d likely be better off with Carveco Maker.
