Tiag dovetail / 800w chinese spindle
I have been procrastinating on this for along while. I wanted a strong mount for the 800W spindle. The 65mm mounts were right for the tiag dovetail. I just needed to extend the universal plate a little. It does not leave much Z-axis movement with the default maker slide. Will probably have to increase its length. Here is the dry fit
What about using Phil’s risers or other lift plates to raise the gantry?
Replace the Entire Z-Axis with a much sturdier z-axis for the 1hp motor? That would be too smart when I could just buy a little longer piece of Maker Slide. Right now just working on dealing with Chinese Grounding! and Err 02 in the VFD. Will worry about having depth when I get up and running :slight_smile:
