Tiling in X axe
I want to use tiling but the longer axe is X is there a way to change the direction of tiling instead of Y?
just enter a greater # “Y” smaller # “X”.
No, Easel’s tiling process does not support open ended X axis.
I’m guessing you have a Bob’s cnc
Bob refuses to tell people how to change the machine to operate like every other hobbyist cnc on the market, but within the grbl firmware, you can edit this setting and re-flash the grbl to fix this and it’ll operate like every other hobbyist CNC on the market.
OR you can do manual tiling the way it used to be done before Easel implemented the integrated tiling function, using the manual method is a bit more tricky but you can do it in Y or X…
