Tiling required and I do not understand why
Can someone please tell me why Easel wants to tile my project.Easel - DavidaBox
As far as I am concerned I believe it is smaller that the 300x180 acrylic material I have specified.
You have the option to enable and/or disable it.
What is your machine work area set to?
Go to machine>edit machine to see this setting.
If your material dimension (top right corner settings) is set larger than the work area, then tiling is activated.
You can either fix the work area / material dimesnions OR manually turn off tiling via the method Ken provided.
