Sure, no problem, was a pretty short list! From OpenBuilds, I ordered:
10X Eccentric Spacers (6mm version) Eccentric Spacer - OpenBuilds Part Store
I also ordered 5mm nylocks from them, but in retrospect I’d just go get them at the hardware store, since they’re the same thing and just as available.
From Home Depot I picked up:
8X 30mm M5 bolts (hex head) - Four for the X carriage, two more for each of the Y endplates.
4X 40mm M5 bolts (hex head) - For the Z, since the X is thicker than the X carriage or the Y endplates.
Washers were just re-used, make sure you don’t lose the spacer washer when you take off the bearings! It’s a tiny little thing, and easy to drop. The whole upgrade took me about 30 minutes, and that was including the time to find the first spacer I dropped and had to hunt for in the carpet. lol
Just pull the existing wheels one at a time, slide the screw back until the wheel will just roll down the rail and clear, pop a longer bolt into it, hang the spacer juuuuust on the end of the bolt, and “roll” it back into position. Slide on the eccentric spacer, top it with a nylock, and tighten up. Snug the eccentric properly, then fully tighten the nylock and that wheel’s done! Repeat until you’re out of wheels to swap, then go around and double-check to make sure all your eccentrics are just right and the assemblies roll smoothly. I only had to re-adjust two out of ten, and that was really, really easy. To adjust them, all you have to do is very slightly loosen the nylock, adjust the eccentric, then snug the nylock back up again. It doesn’t shift the eccentric a bit if you do it carefully. TONS easier!
EDIT: As I think about it, I DID remove the Z carriage. I didn’t really mean to, but when I released the second eccentric, it just rotated clear and popped off. So I took the opportunity to use a toothbrush and really scour the wheels clean of dust, then put the new eccentrics on and rotated it back into position before snugging them down again.
