On easel, my toolpath is correct. When I cut, bit barely cuts and goes off project. Checked wires, stepper motors and everything seems good. Any advice/tips/ resources would be helpful.
can you share the project with us?
go to project>Share and change it from private to unlisted and copy that link and then supply it over here It’s only a copy of your project and we cant make changes to your original via the link, but it would show any design errors / anomalies.
Have you ensured that your GRBL settings are correct for your machine? You need to use the settings for the 3018 and not those for the X-Carve.
Check out this link…
{:0)
Brandon Parker
