I cover a bit of a different method here
I Use Grbl-Panel, but in the post reply, I have the code I use to lower down to my switch.
Yes,went through multiple full power cycles, reseating GShield, etc. no change in results, whether I have anything connected to A5 or not.
@SteveLittlepage v1.0.9.
If you have a multimeter handy, without the Zeroing probes attached check the DC voltage between your spindle and ground. If you have voltage, there may be something leaking power to your spindle. Also, check that you have ~5VDC between your touch plate and your clip when they are not connected to your work surface or spindle. (mine is about 4.87V)
Do you get any error like a soft limit for the error.
On my machine, I have the soft limits on so I cant drive my Z-Axis down to far.
$20 = 1 : enable soft limits
$132 = 64: I can go any farther down than 64mm from my homing position, not z-zero.
What is the machine position when you send the command. If Grbl it sees it as farther than the limit it will stop.
I had just done a homing sequence, so Z had lots of travel left before the limit.
-Kelly
I have exactly the same symptoms as @JonathanTaylor did over in the âTouch Plate not workingâ thread, it seems his arduino was bad, so I guess Iâll be talking to the folks at Inventables support.
-Kelly
Thanks, but the machine doesnât move even without the wires attached, so it canât be a +5 on the spindle.
When I measured voltage between A5 and ground, there was very nearly zero volts DC.
So, I think I may have a bad arduino, Iâve emailed tech support.
Thanks,
Kelly
OK, Inventables Support sent me a new arduino, touch plate works now!
-Kelly
Great!
I got my touch plate working un UGS. (Z height only)
I just used a scrap piece of aluminum I had laying around. It is a bit improvised, I plan on redoing the wiring later
One thing I noticed was that if you are in Absolute Addressing Mode (G90) the bit will move until it reached the specified Z address. Which in this case is bad as I had not set my height yet.
Switching to Relative Addressing mode (G91) insured that it would move the specified amount and then stop if no connection was made.
I wrote out my touch plate code as a macro for UGS and it works well.
Now I just need to figure out how if I can make UGS save macros between sessions.
As it is I have a small txt file that I copy / paste it out of each time I open UGS.
Here is the UGS Macro version of the code I am using:
M5; G17; G21; G91 G38.2 Z-5 F6; G92 z7; G91 G0 z6.25
Here is the G Code I am using with Comments:
(I find writing out the comments helps me understand how the code works)
I just brought A5 and ground out of the Arduino as follows:
Find a âstackable headerâ. If you are an Arduino âhackerâ you should have these in your junk box. I wanted to use a âstandardâ 6 pin version as thatâs how many pins are on the A0 through A5 connector even though you only need A5.
If you think too much of the stackable header pins is exposed, just use a side cutter (diagonal cutting pliers) to shorten.
Grabbing the pins with a pair of needle nose pliers, bend then at a 90 degree angle with respect to the header body. That way, wiring to A5 will come out of the side of the Arduino, similar to the way the limit switch wiring comes out. At first, I thought I could come straight out the top without bending. But, the stepper motor wiring interfered with the A5 wiring and I couldnât move it.
The next problem is that the slot in the metal enclosure near A5 isnât wide enough to accommodate the full 6 pin stackable header. So, using side cutters again, I chopped off 3 of the pins. Some Arduino headers are designed to be broken at each pin. These headers were not, but, chopped off cleanly enough. I wanted to have more than 1 pin, A5, come out for physical âstabilityâ of the connection.
Next, I used a standard 2 pin header to attach the probe cable to the stackable header just installed. I used a 2 pin header because I didnât have a 3 pin header. Crimp a male pin on the red wire and insert into a 2 pin header socket. Crimp another pin, a dummy pin without a wire, and install into the other 2 pin header socket. Again, I used 2 pins for stability.
Connect the black, ground wire, to the shields from the 3 stepper motors. They should be nearby. I also have connected the shields to the power supply ground through a separate wire.
Run the cable through one of the work table holes and terminate as you desire.
If this is too much or you donât have the parts, you might also be able to take a spare Arduino male pin, maybe cut off the strain relief part to make it shorter if needed, and just solder a wire to it and insert in A5.
Here is my solution to the A5 pin connection. I just used a piece of solid coper wire. I think it was door bell wire. I put a little backwards âSâ twist in it and when the GRBL shield is put back on it holds the wire down just fine. Being as stiff as the wire is, it wonât pull out. Fit perfectly and exits out the back of the enclosure with the stepper wires. Once clear of the enclosure I soldered it to a length of quality and flexible speaker wire and ran that to my touch plate. I use it to zero all three axis at one time by loading a short g-code file. Here is a short video of it in action.
nice ! great idea !!
I just found out that the analog input is not used at all !
I wonder if it is possible to connect several switch to manually control the movements of in x-y-z
Not sure what you mean by this. Care to elaborate please?
A0 = Reset/Abort
A1 = Feed Hold
A2 = Cycle Start/Resume
A3 = Coolant Enable
A4 = Not Used
A5 = Probe
Here are the functions for the Analog pins on the Arduino.
Sorry, they are used.
I think you are referring to a âjog controllerâ.
It has been done for several different control softwares.
I donât know if GRBL supports hooking one directly to the controller though. (And if it did you might need another break out board to give you additional pins)
So you are talking about jogging and not zeroing then. If you were talking about combining jog moves to zero the different axis, I have that figured out. I posted a short video showing it happen on the x-carve a couple of posts up. I can now zero x,y,and z axis all at one time without having to run 3 separate commands. Just position the bit next to the touch plate and run a short g-code file and bingo⊠all three axis are automatically zeroed.
Hi,
could you please give a link to the design?
thank you
Iâd love to try making one of these. Could you please send me the Fusion file?
Thanks a bunch!
