Tramming X-axis. I’ve read a ton of posts here and elsewhere and watched a bunch of videos, but havent really found specific info on how exactly to fix it on the X-Carve. i know which way it’s off-axis (leaning forward) just not sure how to adjust. where exactly do i shim it? advice?
Forward leaning means you need to either shim the bottom or rotate the wide makerslide
care to share?
I’d like to know too. Pls share your steps. I recently flattened a sacrificial wasteboard, and there were ridges from z being tilted too far forward
my z axis was leaning back so i put a couple thin washers bbehind the bottom bolts to swing it up and level. took a bit of trial and error, but that was it (in my case)
you can also loosen the four bolts on each side of the X gantry and adjust it there. That’s how I’ve always adjusted mine.
I am reviving this thread, I am having the same issue!
I will try adding washers and go from there, any other advice or images would be very helpful!
read the last post from Pyrex
