So I have carved this sign 3 or 4 times. The first time was great but I forgot to center everything. SO the next time I did it the depth on the clip art was not deep enough eventhough I had it correct. I have doe 2 more and still not correct like it would just barely touch the material. so then I did this one and it is ok but the Goats are different from the original and the one on the right is not the same depth as the left.
Depth is correct same for both, I checked belts, checked probe, I am using a 60 v bit.
Any suggestions? I am nervous about a nicer sign. Also this only happened after I was upgraded to the Easel Pro.
