Trouble shooting Jtech 2.8w laser with Jtech GRBL 0.9g
Hello everyone,
I recently upgrade to the 2.8 Laser from Jtech Photonics, It has worked great with the Vectric post processor but would like to take advantage of the full capabilities the laser has and do some pictures utilizing the PICLaser software
My issue is when I use xloader to load Jtechs hex file for the GRBL. It loads the hex file as far as I can tell. I pasted the text from Universal Gcode sender and shows “Grbl J-Tech Photonics 0.9g G400ok”". When I try and move the Xcarve it wont move and I get a yellow Queue message. If I reload the stock grbl I no issues and can move the xcarve manual or send gcode with ease.
One last thing I ordered another arduino because I thought my version was not genuine. It was an “italy version” the new one I got was a US version. I have the same issue with both versions.
Any help you guys can provide would be greatly appreciated. thank you.
Has anyone had this issue?
**** Connected to COM4 @ 115200 baud ****
Grbl J-Tech Photonics 0.9g [’$’ for help]
F4000ok
$0=10 (step pulse, usec)
$3=3 (dir port invert mask:00000011)
$6=0 (probe pin invert, bool)
$10=3 (status report mask:00000011)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$14=0 (auto start, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=0 (homing cycle, bool)
$100=40.000 (x, step/mm)
$101=40.000 (y, step/mm)
$102=188.976 (z, step/mm)
$130=790.000 (x max travel, mm)
$131=790.000 (y max travel, mm)
ok
You problem is, the grbl setting $14= needs to be set to 1. ($14=1) Later versions of grbl does not have this setting.
that fixed it. i typed in $14=1 and didnt work. then tried $14=1.0 and now everything is working again. its moving but seems a little slower then with the previous version of grbl. i am going to try out a small laser image and see how everything comes out.
where could i read up on the other settings
Thank you for your help.it’s
Here is some more grbl setting changes you can make to increase the performance for laser engraving photos.
Same problem but the motor move just a little bit and make a wird noise.
Someone for help ?
Which version of grbl are you running?
If 0.9g, do you have $14 set to 1.0?
It could be the grbl setting $13=0 also. If he is trying to jog in inch units & Inch Per Minute feedrates when grbl is set to Metric, it will be short & very slow moves. PicSender automatically changes the $30= grbl setting when the jogging units & feedrate values are changed by selecting or Un-selecting Metric on the main screen.
@GautierHenricy Without any details, it’s hard to tell what the problem is that your having.
I’m basically still have this problem. I go through a basic pocket operation (large square to resurface my machine, and I get the now dreaded yellow “Queue” status! Several commands are sent, but not executed. See screenshot.
I have set $14=1.0 but this had no effect. Below are my settings. What is interesting is that if I pause the job and resume, it will finish most of the job. It will not execute the last couple commands. After a few soft resets and $x commands, and possible $H, the machine will suddenly send me a “finished job message.”
This really stinks. I’m using the jtech grbl 0.9
Grbl J-Tech Photonics 0.9g J Tech [’$’ for help]
F4000ok
$11=0.010 (junction deviation, mm)
$14=1 (auto start, bool)
$20=1 (soft limits, bool)
$22=1 (homing cycle, bool)
$110=50000.000 (x max rate, mm/min)
$111=50000.000 (y max rate, mm/min)
$120=250.000 (x accel, mm/sec^2)
$121=250.000 (y accel, mm/sec^2)
$130=764.000 (x max travel, mm)
$131=772.000 (y max travel, mm)
$132=85.000 (z max travel, mm)
Nevermind the fast $110 and $111… i was just running it fast in the air without carving to see if I could get a job to finish.
I would recommend an update of the firmware to this version.
Please read the Readme.pdf file to set up your machine for laser work.
Brilliant. That did it. Thanks so much Larry.
