Hi Guys, I am Martin,
I just started with CNC Carving, and am encountering an issue when offline carving.
My CNC 3018 Pro has a little control box for manual movement and inserting SD cards with G-Code.
Test files and hand written G-Code works well with the offline box.
Easel is working well when connected by USB.
But the exported G-Code from Easel does not work on the manual control box.
I want to position the machine in the basement due to noise.
So Offline carving is quite important for me.
Does anyone have an idea what might be the issue?
I only see when opening the Easel Export file that the G-Code is not formatted.
But that should only be a visual issue, isn’t it?
Thanks for your help!
