Trying to make a clock
Got my X-Carve about a week ago, got it all set up and ran a couple simple projects. So now I would like to cut the numbers on a piece I have that I would like to make a clock out of. Is there a way to equally space the numbers around the face of the piece.
Google search for “clock face vector” would be easiest without calculating spacing
Also heads up, using the search button is a handy tool to find answers and not get bitched at for repeat topics
first stage carve call the bit 1/32 but use the 1/16 second stage use the 1/8 bit and 60 degree or 90 your call.dont foreget to cover the outside ring.
Adjust you depth i made it deep so you could see it.
