Two machines simultaneously?
Currently have a 1000mm Xcarve and considering building an 1800mm machine. Would it be an issue to run both machines at the same time using one Easel account? Would have a laptop and Xcontroller for each machine. Searched and couldn’t find an answer.
Just wanted to make sure before I pursue this.
Thanks
There’s no reason that it wouldn’t work with separate machines.
I’ve been logged in to Easel on multiple machines at the same time. The actual cutting uses the EaselLocal on each machine.
