May I have access to this feature?
Requesting access.
Id like to test too. I have a million projects to try this with.
The two stage cut works like a charm! I advise anyone testing it to update the machine to grbl 0.9, as well as clearing the EEPROM thru the arduino interface Thanks to the Inventables crew, you guys rule!
Thank you, will give feedback as soon as possible
@TylerJeffrey, @SteveSvare, @Flycaster, @BrooksGray, @OmarAhmed, @Steve4—you now have access to the two-stage cutting feature.
Hello,
Can I use Two stage cuts Easel with Carvey ?
Please kindly grant me access to Two stage cuts.
Thanks
I actually got luck carving a tiger image for my sons Cub Scout pack. I was able to change bits, re-zero and finish the project. The only part that was bad was it had to run the whole cut process even though only a small amount of materials was removed on the second pass.
I would love to see new software for this
My X-Carve is on the way. Can I get access to this feature to play around with when it arrives?
Thank you!
A post was split to a new topic: Easel says there’s nothing to cut with the roughing & detail feature
Can I get access to this? Thanks
Hi Chris- I would love to try out the roughing pass feature. Would it be possible for me to try it out?
Thank you.
Scott
I would love to try this feature out. Can you add me to the list too? Thanks!
I would like to have access to this feature. Thank you.
Could you add me to the testing group please
