Two xcarve for one laptop
Hello,
Im getting a second xcarve.
I wld like to know if it is possible to run 2 different projet at the same time using easel and my only one laptop?
Thank you for your help
Not unless you’re familiar with VMware, virtual box or some other virtualization technology where you can allocate one of your usb ports to the virtual machine and run a separate os (running easel) on the VM while easel runs on the laptop os…
Not as far as I know, but it’s not all hard to dedicate a raspberry pi to one or both of your x-carves so you can send a job, then use the laptop for something else.
I only have one x-carve, but I also have a laser cutter and a 3D printer. The x-carve and printer ache have their own raspberry pi so I can multitask.
